Community Member
WS-SUP720-B3 Can't Boot
I have:
1x WS-SUP720 (SW:s72033-ipservicesk9-mz.151-1.SY1.bin on disk1)
1x WS-SUP720-B3 (SW:s72033-ipservicesk9-mz.151-1.SY1.bin on disk1) as a replacement of defective WS-SUP720
The 1x WS-SUP720-B3 can't be boot (only in ROMMON mode) below is the output:
00:00:34: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:34: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor for this switch
00:00:36: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:34: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 13-Aug-10 11:12 by integ Build [100]
00:00:36: %OIR-SP-6-CONSOLE: Changing console ownership to route processor
Everyone's tags (1)
1 REPLY
Try to set the config-register in ROMMON to 0x2102 on both SP and RP:
     confreg 0x2102
     sync
Note that to access RP ROMMON you need to enter break sequence after you see
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards, Ivan Shirshin **Please grade this post if you find it useful.
260
