Community Member
WS-X4013+TS= & PoE
can 12-ports 10/100/1000 802.3af on the Supervisor Engine II-Plus-TS work as simple (not-PoE ports) if not PoE-enabled power supplies are used?
1 REPLY
Bronze
Re: WS-X4013+TS= & PoE
PoE-enabled power supplies are required to support PoE on the twelve 10/100/1000 supervisor faceplate ports* and PoE-enabled line cards added to the Cisco Catalyst 4503.If there is no POE-enabled power supplies it will act as an ordinary port.
266
