ws-x4148-rj45v with linksys spa942
I've got some WS-X4148-RJ45V blades in a Catalyst 4506, and some Linksys SPA942 voip phones. Is there any way to get these phones to power from the 4148 blade? Perhaps force power on a port-by-port basis? Or will I need to replace them with 4248s?
Anthony
1 REPLY
Silver
Re: ws-x4148-rj45v with linksys spa942
Hi Anthony,
There is not need to supply external power supply.
Is phone cannot get power from switch port,
You can configure and test following way,
Switch# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)# interface fastethernet 5/8
Switch(config-if)# power inline auto
Switch(config-if)# end
This example shows how to verify the inline power configuration for the Fast Ethernet interface 5/8.
Switch# show power inline fastethernet 5/8
Interface Admin Oper Power ( mWatt ) Device
FastEthernet5/8 auto on 400 cisco phone device
Switch#
If still you are facing problem please let me know.
Dharmesh Purohti
281
