Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
WS-X45-Sup 7-E sdcard slot
I would like to use the sdcard slot on the supervisor engine card, is this working?  If so can any sdcard work that is 2GB or less?
Everyone's tags (2)
Re: WS-X45-Sup 7-E sdcard slot
yes it does. It was added to be used
Officially only Cisco SD-X45-2GB-E is supported.
Other cards can be tried but there is no guarantee that they will work. Also it is important you are aware of the Cisco Policy for Third Party Components if you are willing to try third party memories:
http://www.cisco.com/en/US/prod/prod_warranty09186a00800b5594.html
hope this helps.
Please rate and close the thread accordingly.
Riccardo
I was looking through for the commands to use to check and see if the sdcard that i put in there was being seen, but i have not been able to find any.  I have looked through the command reference for this model switch.  Any other places where i could look?
it should be dir slot0:
(or show file system to see all the file systems available)
the sdcard still needs to be formatted with FAT?
I will try that when I can get infront of it.
yes FAT32
1089
