WS-X45-SUP7L-E
Dear All,
There is a requirement for 4503 switch with redundant and if I select WS-X45-SUP7L-E , does is support VSS?? Because , IPBase image costing for 9k USD which is require to enable HSRP. Please suggest
Yes but it also needs license
Yes but it also needs license. VSS supported with the Supervisor Engine 7-E, an IP Base license is required, and with the Supervisor Engine 7L-E Enterprise Base license is required.
FYI:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-series-switches/prod_qas0900aecd806d8b06.html
HTH.
RS.
Dear,  Thanks a lot for your
Dear,
Thanks a lot for your reply.
at least i can enable HSRP on this WS-X45-SUP7L-E with IPBASE license.Is that correct?
The 4500X switch the feature
The 4500X switch the feature VSS is supported on IP-Base.
Is there any info on the VSS license for SUP7L-E ?
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_27990-01.html
Second question:
Yes you can enable HSRP feature running the IOS on this.
Below link explains the features supported on IP-BASe / Lan base/Enterprise services:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_26675-01.pdf
Inayath
*Plz rate all usefull posts.
77
