ws-x4516 and ws-x4516/2 - identical or not?
I'd like to know one thing about 4500 switches. Why are part numbers for main and redundant supervisors different? I mean, why two different PNs exist: ws-x4516 and ws-x4516/2? Is it a means of tracking something or the modules are indeed different?
What if I have a 4507R and two ws-x4516 and no ws-x4516/2? Can I build a redundant system and get RPR to work?
BR,
Serge
1 ACCEPTED SOLUTION
Re: ws-x4516 and ws-x4516/2 - identical or not?
To add to Reza's comments, the existence of the two Part IDs doesn't extend beyond the ordering tools/price lists.
If you order a WS-X4516/2 and insert it in a chassis, the output of show mod will display as WS-X4516.
IIRC, the difference in the part IDs exists for the purposes of pricing bundles, but serves no purpose in terms of system operation.
HTH,
Bobby
VIP Super Bronze
Hi Serge,
Here  are the descriptions.  You should be able to build a redundant system.  According to the description the second one is your redundant Sup.
So, you should be fine.
WS-X4516Catalyst 4500 Supervisor V (2 GE),Console(RJ-45)
WS-X4516/2
Catalyst 45xxR Redundant Supervisor V (2 GE),Console(RJ-45)
Reza
HTH,
Bobby
Thank you very much Bobby. Now I got it.
They are physically identical. And having different PNs may indeed come in handy when assigning prices for fancy bundles. It makes perfect sence now.
BR,
Serge
605
