Webcast-Catalyst9k
WS-X4548-GB-RJ45V Card
Does anyone know if  "WS-X4548-GB-RJ45V" card supports poe without any limitation in all interfaces? I have found the following link but it's not clear if it supports poe in all interfaces without any limitation.
Thank you
http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea.html
Green
Yes this supports POE on all ports
WS-X4548-GB-RJ45V:
• 48 ports
• 10/100/1000 (RJ-45)
• Cisco IOS Software Release 12.2(18)EW or later
• IEEE 802.3af and Cisco prestandard PoE, IEEE 802.3x flow control
• Bandwidth is allocated across six 8-port groups, providing 1 Gbps per port group
• Enterprise and commercial: designed to power IP phones, wireless base stations, video cameras, and other IEEE-compliant powered devices
You will need to make sure that 4500 chassis has the correct PSUs to provide POE
alex
Regards, Alex. Please rate useful posts.
thanks
Green
I also meant to point out to you the throughput limitation of this kind of card
This card has 6 ASICS - 1 per group of 8 ports
Each ASIC only has 1Gps back to the backplane so that is 6G in total.
These ports are fine for a say an IP-Phone and a users PC
The are not suitable for highly utilised servers or hevily used uplinks to other switches
Alex
474
