03-18-2014 08:08 AM - edited 03-07-2019 06:45 PM
I have a WS-C4507R+E with two of the WS-X4748-RJ45-E linecards in addition to a single Sup7E.
I need to connect eight 6-port portchannels to the WS-X4748-RJ45-Es.
Since the linecards are described as non-blocking do I need to worry about how I connect/group various portchannels?
A best practice would be to distribute 3 ports from each portchannel to each of the WS-X4748-RJ45-E - correct?
I have seen/read questions about ASIC oversubscription for other switches (3K fixed) and line cards, but cannot find anything similar for the WS-X4748-RJ45-E. Does such documentation exist?
Phil
Solved! Go to Solution.
03-18-2014 10:23 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
On those line cards, with a sup7E, you can connect to any port you desire.
Assuming you want to minimize the bandwidth loss to each portchannel if a line card fails, yes.
That because the "intelligence" for 4500s is within the sup, not the line cards.
03-18-2014 10:23 AM
Disclaimer
Posting
03-18-2014 07:15 PM
Your answer reinforced what I had been able to find otherwise - thanks for the clarification.
