Bronze
WS-X5403 and Etherchannel support
I am trying to figure out if the old Cat5000 WS-X5403 (3-port Gigabit module) linecard supports Etherchannels. I am unable to test this because the interfaces are in production at this time and need to be migrated.
The chassis has the following specs:
sh module
Mod Slot Ports Module-Type Model Sub Status
1 1 2 100BaseFX MMF Supervisor WS-X5530 yes ok
2 2 2 100BaseFX MMF Supervisor WS-X5530 yes standby
4 4 3 1000BaseX Ethernet WS-X5403 no ok
5 5 24 10/100BaseTX Ethernet WS-X5224 no ok
6 6 24 10/100BaseTX Ethernet WS-X5225R no ok
7 7 24 10/100BaseTX Ethernet WS-X5224 no ok
8 8 12 10/100BaseTX Ethernet WS-X5213A no ok
9 9 24 10/100BaseTX Ethernet WS-X5225R no ok
10 10 12 100BaseFX MM Ethernet WS-X5201 no ok
Mod MAC-Address(es) Hw Fw Sw
1 00-10-07-26-77-00 to 00-10-07-26-7a-ff 1.8 3.1.2 5.5(11)
2 00-10-07-26-77-00 to 00-10-07-26-7a-ff 1.8 3.1.2 5.5(11)
4 00-01-42-ea-ee-f8 to 00-01-42-ea-ee-fa 1.3 4.5(2) 5.5(11)
5 00-10-7b-07-d1-68 to 00-10-7b-07-d1-7f 1.3 3.1(1) 5.5(11)
6 00-d0-06-a2-81-98 to 00-d0-06-a2-81-af 3.3 4.3(1) 5.5(11)
7 00-10-7b-78-f7-a8 to 00-10-7b-78-f7-bf 1.4 3.1(1) 5.5(11)
8 00-e0-1e-e8-71-1c to 00-e0-1e-e8-71-27 2.1 3.1(1) 5.5(11)
9 00-50-0f-b5-fe-c8 to 00-50-0f-b5-fe-df 3.1 4.3(1) 5.5(11)
10 00-10-7b-62-f7-64 to 00-10-7b-62-f7-6f 3.0 3.1(1) 5.5(11)
All three gigabit interfaces are active on different buses (1=A, 2=B, 3=C)
regards,
Geert
1 ACCEPTED SOLUTION
Re: WS-X5403 and Etherchannel support
Run the following command against the interfaces :-
show interface x/x
Below is an example, note the section Channel: yes
sh interfaces gigabitEthernet 11/1 capabilities
GigabitEthernet11/1
Model: WS-X6148-GE-TX
Type: 10/100/1000BaseT
Speed: 10,100,1000,auto
Duplex: half,full
Trunk encap. type: 802.1Q
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: none
Flowcontrol: rx-(off,on,desired),tx-(off,on,desired)
Membership: static
Fast Start: yes
QOS scheduling: rx-(1q2t), tx-(1p2q2t)
QOS queueing mode: rx-(cos), tx-(cos)
CoS rewrite: yes
ToS rewrite: yes
Inline power: no
Inline power policing: no
SPAN: source/destination
UDLD yes
Link Debounce: yes
Link Debounce Time: no
Ports on ASIC: 1-24
Remote switch uplink: no
Dot1x: yes
Port-Security: yes
show interface x/x
GigabitEthernet11/1
Duplex: half,full
Channel: yes
Membership: static
Fast Start: yes
CoS rewrite: yes
ToS rewrite: yes
Inline power: no
UDLD yes
Link Debounce: yes
Ports on ASIC: 1-24
Dot1x: yes
Port-Security: yes
Bronze
Thanks, should have known that...
(ps. its still CatOs, so command is show port capabilities:)
>>sh port capabilities 4/1
Model WS-X5403
Port 4/1
Type 1000-LX/LH
Speed 1000
Duplex full
Trunk encap type 802.1Q,ISL
Trunk mode on,off,desirable,auto,nonegotiate
Channel no
Broadcast suppression percentage(0-100)
Flow control receive-(off,on,desired),send-(off,on,desired)
Security no
Membership static
Fast start yes
QOS scheduling rx-(none),tx-(none)
CoS rewrite no
ToS rewrite no
Rewrite no
UDLD yes
AuxiliaryVlan no
SPAN source,destination
It clearly states: "no". Da**ned. There goes my migration plan :-)
I have felt that pain many times, good luck with the new plan.
142
