WS-X6148-GE-45AF supported for VSS ?
I want to know if the module WS-X6148-GE-45AF is supported for VSS or not. If yes which IOS version i needed.
The module is working fine with out VSS but when VSS is configured the module is not getting power form switch.
Sh module output is given below for switch with VSS and Without VSS. I need ur help urgently..
Thanks.
_________________________________________________________________________________________________________________
WITHOUT VSS CONFIGURED ...............................
#sh module
Mod Ports Card Type                              Model              Serial No.
  1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1309L4SN
  2    6  Firewall Module                        WS-SVC-FWM-1       SAD13050148
  3   48  48 port 10/100/1000mb EtherModule      WS-X6148-GE-45AF   SAL1309KW32
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL124056Z6
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0024.97da.10bc to 0024.97da.10d3   3.3   12.2(18r)S1  12.2(33)SXI3 Ok
  2  0021.a082.7b08 to 0021.a082.7b0f   4.5   7.2(1)       4.0(8)       Ok
  3  0024.c472.6638 to 0024.c472.6667   8.2   7.2(1)       12.2(33)SXI3 Ok
  5  0019.e8bb.77cc to 0019.e8bb.77d3   3.0   8.5(3)       12.2(33)SXI3 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       SAL1308K4J4  4.1    Ok
  3  IEEE Voice Daughter Card    WS-F6K-48-AF       SAL1309KUKS  2.3    Ok
  5  Policy Feature Card 3       VS-F6K-PFC3C       SAL1309KLLZ  1.0    Ok
  5  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL1308K2LC  1.1    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
  5  Pass
WITH VSS CONFIGURED.............
#sh module switch 1
Switch Number:     1   Role:   Virtual Switch Active
  3  0024.c472.6638 to 0024.c472.6667   8.2   Unknown      12.2(33)SXI3 PwrDown
  3  IEEE Voice Daughter Card    WS-F6K-48-AF       SAL1309KUKS  2.3    PwrDown
  1  Pass
  2  Pass
  3  Not Applicable
  5  Pass
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: WS-X6148-GE-45AF supported for VSS ?
Hello Taha,
this is a known limitation only modules of type 67XX are supported in VSS
see
The VSS requires 67xx series switching modules.
The VSS does not support classic, CEF256, or dCEF256 switching modules. In virtual switch mode, unsupported switching modules remain powered off.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1053927
so as far as I know there is no IOS version that will support the WS-X6148 in a VSS chassis and likely it will not exist in the future.
Hope to help
Giuseppe
1 REPLY
Hello Taha,
see
Hope to help
Giuseppe
602
