WS-X6148-RJ-45 , WS-X6248-RJ-45 OIR
chungandrew
I just replaced the WS-X6248-RJ-45 with WS-X6148-RJ-45 within the same slot for Catalyst 6509 Switch . However , I can't config the FE port in WS-X6248-RJ-45 into switchport as below indicated :
(config-if)#interface FastEthernet7/4
(config-if)# no ip address
(config-if)# switchport
(config-if)# switchport mode access
Command rejected: Fa7/4 not a switching port.
While I put the WS-X6148-RJ-45 back to the same slot , the same error message appear , that mean I can't place the port for this subject slot (No matter with WS-X6148-RJ-45 or WS-X6248-RJ-45)
back to "switchport" any more .
I am wondering if the OIR for this two module make it happen and if I have to reboot the system to make it come back to normal condition as the default setting for the ports of these two module was supposed to be "switchport" !!
Amit Singh
What happens when you give only the following commands:
And then check, " Show int fa 7/4 switchport "
What is the IOS that you are running on the BOX. Please paste the "show version " and " show module" from the chassis.
Also try reseating the module back in the chassis and see if that makes any difference.
-amit singh
The system accept the command without reject message but I find the switchport status was "disabled" by "Show int fa 7/4 switchport" command . The show result was attached below !!
router> show version
IOS (tm) c6sup2_rp Software (c6sup2_rp-PSV-M), Version 12.1(13)E9, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Sat 12-Jul-03 20:41 by hqluong
Image text-base: 0x40008C00, data-base: 0x4179C000
ROM: System Bootstrap, Version 12.1(3r)E2, RELEASE SOFTWARE (fc1)
BOOTLDR: c6sup2_rp Software (c6sup2_rp-PSV-M), Version 12.1(13)E9, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
C80603-6509-01 uptime is 3 years, 46 weeks, 2 hours, 0 minutes
Time since C80603-6509-01 switched to active is 3 years, 46 weeks, 2 hours, 18 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 06:07:56 CST Tue Sep 9 2003
System image file is "slot0:c6sup22-psv-mz.121-13.E9.bin"
cisco Catalyst 6000 (R7000) processor with 458752K/65536K bytes of memory.
Processor board ID SAD05050HSY
R7000 CPU at 300Mhz, Implementation 39, Rev 2.1, 256KB L2, 1024KB L3 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
1 FlexWAN controller (1 ATM).
22 Virtual Ethernet/IEEE 802.3 interface(s)
240 FastEthernet/IEEE 802.3 interface(s)
20 Gigabit Ethernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
381K bytes of non-volatile configuration memory.
16384K bytes of Flash internal SIMM (Sector size 512K).
Standby is up
Standby has 458752K/65536K bytes of memory.
router> show module ---> 6148
Mod Ports Card Type Model Serial No.
1 2 Catalyst 6000 supervisor 2 (Active) WS-X6K-SUP2-2GE SAD05060NE0
2 2 Catalyst 6000 supervisor 2 (Standby) WS-X6K-SUP2-2GE SAD05060NGF
3 0 2 port adapter FlexWAN WS-X6182-2PA SAD06070554
4 8 8 port 1000mb GBIC Enhanced QoS WS-X6408A-GBIC SAD05040L3E
5 8 8 port 1000mb GBIC Enhanced QoS WS-X6408A-GBIC SAD05040LAE
7 48 48-port 10/100 mb RJ45 WS-X6148-RJ-45 SAL08229EJ9
8 48 48 port 10/100 mb RJ-45 ethernet WS-X6248-RJ-45 SAD04270NDF
Mod MAC addresses Hw Fw Sw Status
1 0002.7ec1.0dea to 0002.7ec1.0deb 2.2 6.1(3) 7.5(0.6)HUB1 Ok
2 0001.6414.eee6 to 0001.6414.eee7 2.2 6.1(3) 7.5(0.6)HUB1 Ok
3 0002.7e38.b2ec to 0002.7e38.b32b 1.4 12.1(13)E9 12.1(13)E9 Ok
4 0001.c9b0.ab3c to 0001.c9b0.ab43 1.4 5.4(2) 7.5(0.6)HUB1 Ok
5 0001.c9b0.acfc to 0001.c9b0.ad03 1.4 5.4(2) 7.5(0.6)HUB1 Ok
7 0011.213b.e448 to 0011.213b.e477 3.1 5.4(2) 7.5(0.6)HUB1 Ok
8 0002.fc23.1e28 to 0002.fc23.1e57 1.4 5.4(2) 7.5(0.6)HUB1 Ok
Mod Sub-Module Model Serial Hw Status
1 Policy Feature Card 2 WS-F6K-PFC2 SAD05060LP5 1.3 Ok
1 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SAD05050HSY 1.2 Ok
2 Policy Feature Card 2 WS-F6K-PFC2 SAD05060LU3 1.3 Ok
2 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SAD05060R68 1.2 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Not Supported
4 Pass
5 Pass
7 Pass
8 Pass
router> show module ---> 6248
7 48 48 port 10/100 mb RJ-45 ethernet WS-X6248-RJ-45 SAD041509N5
7 0001.9712.8530 to 0001.9712.855f 1.2 5.1(1)CSX 7.5(0.6)HUB1 Ok
1 Pass
2 Pass
3 Not Supported
4 Pass
5 Pass
7 Pass
8 Pass
