WS-X6148A-GE-45AF
Hi!
Is this module:WS-X6148A-GE-45AF supported by Catalyst 6500 with Sup720?
If not which PoE modules are supported?
Thanks.
Re: WS-X6148A-GE-45AF
Yes this 48 ports card offers PoE until 15,4W per port. It works with Sup720 supervisor card.
Pls rate if that help.
Best regards.
Hi, Yassine!
have you used this card on a sup720 or are you guessing?
I need to be 100% sure since in the past I have had some issues with cards not working on sup32.
Thanks.
317
