05-13-2010 02:39 AM - edited 03-06-2019 11:04 AM
Dear All,
we have a Catalyst 6506-E switch with Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-VM), Version
12.2(33)SXH4, RELEASE SOFTWARE (fc1).
Recently we bought a WS-X6148A-GE-TX card and we installed the card to the chassis. the 6506-E looks like recognize the card but unfortunately the status shows Powerdown and Fw/Sw shows unknown ??
Mod Ports Card Type Model
4 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-TX
Mod MAC addresses Hw Fw Sw Status
4 c47d.4f9d.3b50 to c47d.4f9d.3b7f 4.0 Unknown Unknown PwrDown
any idea?
Thanks to all in advance for your kind support.
regards,
mico
05-13-2010 07:00 AM
The problem could be a incompatibility between the supervisor card used, the IOS version and its support for the GE module.
Hope the following chart with the minimum required supervisor/IOS helps.
Regards.
05-13-2010 07:20 AM
Hi Jorge,
thank you for your kind reply. we have Supervisor Engine 720 10GE with IOS version 12.2(33)SXH4 installed.
05-13-2010 07:28 AM
How many modules are there on the switch. Is there enough power for all of them?
Please, see power requirements for this module.
–Module current— 2.50A
–Module power—105.00 W
–AC-input power—131.25 W
–AC heat dissipation—448.22 BTU/hour
–DC-input power—141.13 W
–DC heat dissipation—481.96 BTU/hour
Regards.
05-13-2010 07:47 AM
I have 4 modules as listed below. could be power issue as you mentioned. I will double check and let you know.
1 24 CEF720 24 port 1000mb SFP WS-X6724-SFP
2 24 CEF720 24 port 1000mb SFP WS-X6724-SFP
5 5 Supervisor Engine 720 10GE (Active) VS-S720-10G
mico
05-13-2010 07:51 AM
how many power supply is on the 6500? are they setup in redunant mode?
05-13-2010 07:52 AM
issue "show power redundancy-mode"
05-13-2010 08:06 AM
Hi Francisco,
thank you for your support. on the 6500 we have two PS and they are redundant. here is the details about the power. I did not try to install then on different slot. I will do that too and i will update you about the result.
Thank to all for the support and assistance.
mico
system power redundancy mode = redundant
system power total = 5771.64 Watts (137.42 Amps @ 42V)
system power used = 1063.02 Watts (25.31 Amps @ 42V)
system power available = 4708.62 Watts (112.11 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 WS-CAC-6000W 5771.64 137.42 OK OK on
2 WS-CAC-6000W 5771.64 137.42 OK OK on
Pwr-Allocated Oper
Fan Type Watts A @42V State
1 WS-C6506-E-FAN 98.70 2.35 OK
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @42V Watts A @42V State State
1 WS-X6724-SFP 162.96 3.88 162.96 3.88 on on
2 WS-X6724-SFP 125.16 2.98 125.16 2.98 on on
4 WS-X6148A-GE-TX 105.00 2.50 - - on off (not supported)
5 VS-S720-10G 338.10 8.05 338.10 8.05 on on
6 (Redundant Sup) - - 338.10 8.05 - -
05-13-2010 07:31 AM
Can you post a "sh env/sh env power/sh power" (sorry i can never remember which one !!).
Also you are not running VSS are you ?
Jon
05-13-2010 07:43 AM
"show envir status module 4"
Francisco
05-13-2010 07:54 AM
Hi Jon,
thank you for your reply and guidance.
yes we are running VSS.
we installed the cards ot the two 6506-E and we are facing the mentioned problem.
05-13-2010 08:03 AM
You cannot run this card in a VSS system. You need all WS-X67xx modules in a VSS system, see the VSS Q&A for details of supported modules -
Jon
05-13-2010 08:07 AM
Yes,
That module is not compatible with VSS. See my VSS hardware details to have an idea:
2 x C6506-E running IOS 12.2-33SXI
SUP720 10GE
WS-X6748-GE-TX module
2 x WS-CAC-3000W power supplies.
Regards.
05-13-2010 07:44 AM
Jon,
Good you asked the question about VSS. Yep the 6148 will not work...
Francisco
