WS-X6516-GE-TX on WS-X6K-SUP1A-2GE
Is WS-X6516-GE-TX module supported on supervisor engines WS-X6K-SUP1A-2GE? We inserted the module on the chasis, but the module never came on, while the switch acted strangely, stopped forwarding the frames, and nothing we could see on logs.
Dardan
Hall of Fame Super Blue
Re: WS-X6516-GE-TX on WS-X6K-SUP1A-2GE
According to the 6500 data sheet yes it is.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_data_sheet0900aecd8017376e.html
If the module is not coming online you may need an upgrade of your software.
In addition to previous message attached is a link showing minimum CatOs/IOS requirements for this blade.
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_eol_notice09186a00801f3518.html
One last point. This blade is fabric enabled but you will only be able to use the shared bus connection unless you upgrade your supervisor to either a Sup2 with an additional Switch Fabric Module or a Sup720.
Jon
334
