WS-X6548-GE-TX auto trunks when port channeling
cclinard612
We're having an issue with the above blade installed in a Catalyst 6506.  It seems that when configuring the port channel, the port channel is automatically trunked.  I haven't found a way to disable this as of yet and am thinking it may be just a limitation of this particular blade.  We need this particular port channel to not be trunked because it's connected directly to a VM, not a switch.  Any input is appreciated!  Thanks!
6 Replies 6
Reza Sharifi
It may be that the Portchannel is configure as trunk.  If it is then the physical ports will inherit the config from the Portchannel.
Can you post the config for the Portchannel and the physical ports?
interface Port-channel1
switchport
switchport access vlan 10
switchport mode access
no ip address
shutdown
interface GigabitEthernet6/4
switchport
no ip address
shutdown
spanning-tree portfast
interface GigabitEthernet6/5
switchport
no ip address
The port channel is currently shutdown since it's not working correctly.  Ports 6/4-5 are the ones we want to be a member of the port channel group.
"switchport trunk encap dot1q" can't be removed until you remove the ports from the port channel.
Thanks for the input!
Hey,
Just adding my bit to the post. Try defaulting the interfaces, all of them and rebuild. In global configuration mode:
#default interface Po1
#default interface G6/4
#default interface G6/5
#int po1
switchport
no shut
#int g6/4 -5
#channel-group 1 mode active/on
HTH.
RS.
Try this:
no interface Port-channel1
then
default interface gigabitEthernet 6/4
default interface gigabitEthernet 6/5
now
switchport
channel-group 10 mode active
shut
switchport
shut
go to po interface
interface po10
switchport
switchport access vlan xx
no sh
This should bring up the portchannel interface and the physical interfaces in access mode.
Will try tonight and report back.  Thanks for the help.
We came across a setting on the vSwitch that was causing the issue.
"Route based on the originating virtual port ID" was selected on the properties of the server and causing the port channel to fail.  Needed to be de-selected.
Thanks for taking a look with us!
