Webcast-Catalyst9k
Bronze
WS-X6748-GE-TX Latency within the module and between modules
Hi all,
Does anyone know what is the latency (milli-second or micro-second) of the ws-x6748-ge-tx with DFC card module within itself and between module? I have read of the performance below:
Forwarding architecture: These modules use the central  Cisco Express Forwarding engine located on the supervisor engine; optional  field-upgradable Distributed Cisco Express Forwarding daughter cards are  available.
Forwarding performance: These modules forward packets  up to 30 Mpps per system; they forward packets up to sustained 48 Mpps per slot  for slots equipped with distributed forwarding cards (DFC or DFC3).
Fabric connection: These modules connect to the  switch-fabric channels using dual 20 Gbps switch-fabric channels (40 Gbps  total).
I aslo found a document that mentioned an average of 12.349 micro and a max of 16.6 but it doesn't mention if that's between the module itself or module to module.
396
