Community Member
WS-X6748-GE-TX with WS-F6700-CFC daughter card Diagnostic Problem
Softwareversion: s72033-pk9s-mz.122-18.SXD5
See attached word document for fault description.
Community Member
Re: WS-X6748-GE-TX with WS-F6700-CFC daughter card Diagnostic Pr
Just wanted to confirm if this could be slot 6 failure and hence need chassis change or should we first try to replace the SUp720.
Two different WS-X6748-GE-TX fails diagnostics in slot 6, but passes in slot 4.
Community Member
Hi Alphonse,
I think slots 5 and 6 in the 9 slot chassis can only be used for SUPs and not for any line cards.
Kevin
Purple
Think Brennan hit it on the head , slot 6 is reserved for a redundant supervisor.
Community Member
In 9 slot chassis if you don't have second SUP module, slot 6 can be used for line card.
This customer has two CORE switches. Both have the same line card in slot 6. One works and one doesn't and has the problems that I described in previous entry.
995
