Webcast-Catalyst9k
WS-X6848-GE-TX - Ingress Queuing needed?
I've found the following info in the Cisco Live document "BRKRST-2500 Campus QoS Design":
On WS-X6748-GE-TX CoS-based Ingress queuing is not recommended (use linecard at access-layer only)
My question now is:
Is this also true for the WS-X6848-GE-TX?
Everyone's tags (5)
1 REPLY
Super Bronze
Re: WS-X6848-GE-TX - Ingress Queuing needed?
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I believe the 6848 is,more or less, identical with a 6748 with a DFC4 installed.  If so, I would expect them to be often treated alike concerning usage recommendations.
I'm guessing the recommendation might be because both cards only have 40 Gbps to the fabric, but 48 gig ports, i.e. they're oversubscribed.  If so, you should also be able to avoid any need for ingress queueing by using less ports.
393
