Resolved! SLM248G latest firmware
Hi thereHas anybody by chance still the latest firmware for the small business switch SLM248G? Since it's EOS it's not anymore available in the official database...Thank you very much for checking.
The content you are looking for has been archived. View related content below.
Hi,we are facinf and issue with ping from access to corecore management vlan 98 192.168.98.1 255.255.255.0vlan 103 192.168.103.1 255.255.255.0trunk port enabled for vlan 103able to ping access switchAccess switch management vlan 192.168.103.137 255.2...
Hello Everyone. I am working on replacing juniper GW(production)switches with C9500’s. Those junipers are in active standby.My approach is pre-stage cisco switches copy configs from juniper to cisco. Here one question is juniper GWs are using vrrp fo...
Hello Bro,I am looking at the rack mount information about 9200CX, but could not find the clearance it may require to dissipate the heat from the switch. Does anybody share if the switches can be stacked tightly one on top of the other?Much appreciat...
Hey, i am working on a project And I have problems with my DHCP server. I don't remember how it came about. Hence I am asking here. I don't understand why my laptops at the bottom are not getting ip? Anyone who can help me. Packet tracer + Network di...
hi all,we have a topology without any redundant link. Every access switch is directly connected with the core switch, and it's a port-channel between access switch and the core. RSTP runs on switches by default, and we do not explicitly configure the...
Hello all,20+ years ago I used debug all the time, however not so much so in the last decade. Seems like last time I called TAC on the 3850 debug command they gave me some silly answer that debug was a Cisco TAC command. WFIW All the Cisco.com debug...
Hi, Do you have been happen this logging show that, and there are none any effect to our netwoek bunisness. im client 'chasfs' has taken 332 msec (runtime: 332 msec) to process a 'stack chasfs fd' messageMar 28 23:25:32.568: %IOSXE_INFRA-6-PROCPATH_C...
First I'll state i also have an open case with Vmware. I inherited a vPC pair that had a number of vPC set up, but the multiple links to the VxRail host nodes were trunk links. We lost the secondary so only the trunks to the primary vPC were up. A...
Hello, I can't manage to give the connected PCs an ip through the dhcp server. My packet tracer + network design are attached. Have currently only started on the bottom part so it's only about the bottom PCs.Thanks in advance for the effort
I am trying to configure a trunk port on a Cisco 3750 that has fiber running to a ruckus 7150 switch.My current config connects the switches but it is only passing vlan1 traffic and I want multiple vlans. Therefore, I configured the port as a trunk o...
Hello everyone!I'm not a network engineer but as a subsystem (kernel + filesystem) engineer I know the network concept.Few months ago, I designed a DMZ and configured my 2 node VPC with 6 rack switch.Everything was smoothly working but I started to s...
On Nexus 7000s I want to limit bandwidth of particular IP. I can do this using proper configuratio of IP ACL, policy map and class map. But what if I dont have information on interface? Can I apply bandwidth control for particular IP without knowing...
I have a less then a dozen Cisco 3850 switches that I am working on. I need to configure 802.1x authentication. The issue is the switches are reaching out to Cisco ACS and I need to set up radius server to enable 802.1x. The Cisco ACS I found out ...
Am trying to create a new local account on a Nexus 3048 so I can SSH to it if my Radius server doesn't work. Normally, I log in with my AD account which the switch uses Radius for authentication with that. However, when I run the command to create ...
Subject | Author | Posted |
03-29-2024 06:33 AM | ||
03-26-2024 10:12 AM | ||
03-19-2024 05:09 AM | ||
03-18-2024 10:42 AM | ||
03-14-2024 06:05 AM |
User | Count |
11 | |
11 | |
7 | |
6 | |
5 |
