Webcast-Catalyst9k
XENPAK and X2 optic
Can XENPAK on Cat6509-E WS-X6708-10G-3C communicate with X2 optic on Cat4507R WS-X4516-10GE?
Re: XENPAK and X2 optic
Yes, but use the same Type both -SR or both -LX4.
Andy
That is great, but is there a cisco or other document that verifies the compatibility between X2 and XENPAK transceivers?
Mladen
Bronze
Check this link and refer to the last question...
http://www.cisco.com/en/US/netsol/ns668/netqa0900aecd80534905.html
Rajat Setia
Thanks. This was what I was looking for:
Q. Given that the 8-port 10 Gigabit Ethernet module has X2 optics, can I connect a device that supports XENPAK optics?
A. X2 and XENPAK optics differ in form factor only. You can connect an X2 to a XENPAK as long as the optics are of the same transceiver type.
Yes, I am currently doing this in my data center. I have multiple 4948-10G's connected back to my core 6509's. The 6509 uses the 8-port blade.
As someone has already said, they must be the same type (wavelength) on both ends.
420
