03-18-2017 03:07 PM - edited 03-08-2019 09:48 AM
I was having an issue with a c2960x with corrupted IOS.
I formatted the flash and not I can not copy a new IOS to the switch.
I am at a switch: prompt
I ran flash_init and received it was already loaded.
I ran set BAUD 115200 and configured HyperTerm to the same.
I have tried copy xmodem: flash:c2960x-universalk9-mz.152-2.E6.bin and then started receive file and still get this error.
Not sure what is happening.
Paul Logan
Solved! Go to Solution.
03-18-2017 03:47 PM
2960X has a USB port and with a supported USB flash drive, one can boot the IOS from it.
03-18-2017 03:47 PM
03-20-2017 12:06 PM
Thank you Leo, that did the trick.
Have a wonderful week.
03-20-2017 12:42 PM
Thanks for taking the time to rate our posts, Paul. :)
02-18-2018 04:03 AM
am also facing the same issue but switch model c2960PC-L
there is no usb port any other solution ?
06-12-2020 08:48 AM
Надо освободить память на flash. Ошибка из за нехватки памяти
06-12-2020 09:52 AM
и выполнить команду flash_init
