I would like to know what type of hashing/encryption does Cisco SG300-10 uses for admin password and if can be decrypt. NHF-SG300-FB19v1.4.5.02 username admin password encrypted 27f19e480e70952b364d9c47a4f2221e8d97bdf1 privilege 15 Thanks!
The content you are looking for has been archived. View related content below.
Hello Guys ,I am new to to firewall.I have worked in routing and switching domain.Due to some bug i have to upgrade my fw in current company.I have this fw in HA.Below are old,new firmware and hardeware details.Kindly help me with steps from start to...
Hello experts, I have distributed ISE deployment. PAN Primary, PAN Secondary, and 8 PSN. All of them are hardware appliance. I need to replace PAN Primary with new hardware because the old one is End-of-Sale and will be Out-of-Support soon. I would a...
Hi Team,Please can confirm what the below config is try to achieve?Is it doing a PAT to the outside interface then allowing 10.0.255.0 coming from the outside interface to access anything? access-list outside extended permit ip 10.0.255.0 255.255.255...
We are trying to use a key that comes from a Veracity NTP Timenet Pro and authenticate a Cisco 3850 with this key. Has anyone tried using one of these and if so how did you implement the key.. If not, here is a key below.. How would I implement this ...
Hello,Currently running FMC 7.3.1 on both primary and secondary in HA. I setup SSO with our primary just fine and when I try on the secondary device its giving me a 503 service unavailable error. The documentation calls out you need to setup SSO on e...
Does Cisco have physical/hardware WAF like f5, imperva, barracuda or other vendors offer ?
Listen here: S10| E31 Safeguarding Operations: Exploring the Challenges and Solutions for Industrial Security As industries become increasingly interconnected and reliant on technology, the need for robust security measures has never been more critic...
Hi all ,i have CBS 350 Switch and i made Port Security Configurations to the ports with 1 mac address and all is OK ,the Question here : i have Ports on mode trunk and 2 different Vlans I want to stick mac for one vlan only and let the other one with...
Hello,Perhaps this is not a good way to go about it/it is not supported, but I am trying to configure RADIUS such that only specific users can enable past privilege level 1 and all others are blocked, even if they know the enable password (in practic...
I'm following the course Endpoint security, and I've installed the Cybersecurity_Lab_VM_Worksation_20230210.I cannot complete the Lab 4.2.8 Attacking a mySQL Database.In the /home/analyst/ directory, I cannot find the lab.support.files directory wher...
Hi, I would like to have documentation about Cisco Advanced WAF and Bot protection. I've seached against community and salesconnect but didn't find any guide on how to implement it. I'm referring to this solution https://www.cisco.com/c/en/us/product...
Hello Team,I have a theory here, kindly let me know if its Practical.Am managing FTD on fmc, I backup up the configurations.I then remove FTD being managed by FMC and manage it by FDM.AM i able to restore the configuration now using the FDM?Has anyon...
recently I got to compare two vulnerability tools and both were providing different results, to validate it I checked using Cisco software checker and also the Bug ID checker... but it put me in more confused state. can someone guide me on the below ...
Hi everybody, my name is Stephanie and I connect customers with the teams working on new features for security products such as Secure Cloud Analytics, Secure Endpoint, Firewall products, XDR and more. I'm reaching out today because we are looking f...
Subject | Author | Posted |
03-14-2024 11:57 PM | ||
03-08-2024 08:35 AM | ||
02-28-2024 12:11 PM | ||
02-27-2024 07:31 AM | ||
02-19-2024 12:31 AM |
