Cisco GSS and MARS
Can MARS discover Cisco GSS.
1 ACCEPTED SOLUTION
Re: Cisco GSS and MARS
No. Seed file only supports certain device types.
You'll need to define the device and custom parser entries before you can go to the Security and Monitor device page to add it manually to the appliance.
The GSS is not natively supported on MARS. To support it you would need to create a custom parser then add the device as that custom type.
Does it hold true for any reporting device, any brand.
By adding the device as custom type, do you mean via seed file.
Thanks.
Please confirm whether with customer parser method all the device types are supported.
Can you elaborate on your request? I'm not quite understanding what you are asking.
190
