Community Member
CS-Mars 5.2.4.2487 Recovery process fails
Hi All,
For various reasons I have a cs-mars local controller that I need to recover. I dont need any of the existing config or data from it I just need it to function again.
I have tryed to to recover the system using a cs-mars recovery disk 5.2.4.2487, but 15-20 minuets into the process I get a list of error messages all saying rougly the same thing:
/cdrom/bin/tar: lib/modules/2.6.9-42.0.2.ELhugemem/modules.<multiple module names here>: Could not create file: no such file or directory
I have ran the install now multiple times with fresh copies of the disk image, all with the same result. If I now try and boot the box as is, then all I get is half a lilo promt ie: li-
Any ideas how I can recover this box?
Cheers
Everyone's tags (1)
1 REPLY
Re: CS-Mars 5.2.4.2487 Recovery process fails
I would suggest using a newer (or different) recovery image version. Please verify its MD5 hash after download.
Farrukh
953
