CS-MARS, data archiving issue.
andrea.meconi
Level 2
Level 2
Hello at all.
I'm using CS-MARS-20.
Reimaged, restored and upgraded to software version 6.1.8, I'm not able to start data archiving successfully.
I have configured data archiving using a remote SFTP server, click Apply, Start and Activate: data archiving status is running, service is enabled and remote server is available.
But MARS doesn't archive nothing!
Using another SFTP remote client with the same account used from appliance, I can create folders, files and remove.
Any ideas?
Thanks.
Regards.
Andrea
andrea.meconi
Level 2
Level 2
Today, after a reboot, a check to the remote host status reports the following error message
Error: Invalid Remote IP, Path or Connection Error, Unable to Mount
How can I delete the SSH key for this remote host?
Thanks.
Andrea
Now we are moving to a NFS solution.
Data archiving status is running, archiving service is enabled and remote server is available but events, incidents and configuration are not exported.
I can use CLI (pnexp command) to export configuration successfully.
Any ideas?
Why data archiving doesn't work?
Thanks.
Andrea
Hi Andrea,
Is your issue got resolved?
Try with NFS server mount point and will work with version 6.1.6
Note: You can't delete the archived file from the drive. Once it is filled up, you have to create new mount point and configure the same.
Bala
