Community Member
FWSM and IDS module
FWSM and IPS module is in the Core Switch.There is no telnet option from switch to FWSM and IPS module.So can i add the module as separate device...If add what are the changes to be done.
1 REPLY
Silver
Re: FWSM and IDS module
The FWSM allows Telnet connections to the FWSM for management purposes. You cannot use Telnet to the lowest security interface unless you use Telnet inside an IPSec tunnel. The FWSM allows a maximum of 5 concurrent Telnet connections per context, if available, with a maximum of 100 connections divided between all contexts. You can control the number of Telnet sessions allowed per context using resource classes.
http://www.cisco.com/en/US/docs/security/fwsm/fwsm31/configuration/guide/mgacc_f.html#wpxref11628
214
