06-19-2009 10:36 AM
I've been given a 4.2.4 system to look into since the previous admin left some time ago.
I have found we are seeing the following
Error pn datax IncidentXmlNotificationServlet PN-1100: Java message: Error sending XML Notification. Incident Queue is full.
and we no longer get the previously configured XML emailed actions when a rule gets hit.
I have been looking trying to determine what and how needs to be cleared.
Any insight would be appreciated.
Solved! Go to Solution.
06-22-2009 11:59 AM
No problem, I'm glad I could help.
Please rate any posts you find helpful.
Farrukh
06-21-2009 06:10 AM
Did you try restarting the MARS services via the CLI?
Or a reboot if possible.
Farrukh
06-22-2009 07:42 AM
Actually that is what I did (reboot) and functionality has returned.
Thanks for suggesting something so obvious that I didn't think about that. I guess I wanted to make the issue and resolution more complex that it needed to be.
06-22-2009 11:59 AM
Farrukh
