Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Java Process Consuming 99% CPU
I recently noticed our CS-MARS (v.6.0.7) appliance running kind of slow (slower than usual). I logged into the appliance through CLI and ran a systatus and noticed that the java process was fluctuating between 95-99% utilization:
sysstatus - 15:37:40 up 53 days, 18:04,  1 user,  load average: 1.45, 1.45, 1.27
Tasks: 189 total,   1 running, 188 sleeping,   0 stopped,   0 zombie
Cpu(s): 27.2% us,  3.4% sy,  0.0% ni, 66.1% id,  3.2% wa,  0.1% hi,  0.0% si
Mem:   8296844k total,  8275336k used,    21508k free,    34940k buffers
Swap: 16777208k total,    23660k used, 16753548k free,  5271320k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
22917 pnadmin   16   0 1293m 1.1g  17m S 99.1 14.3 263:30.97 java
29181 pnadmin   17   0  708m 282m  15m S  3.7  3.5   1164:26 pnparser
28994 pnadmin   16   0  138m  49m 8024 S  1.7  0.6 551:44.98 pnarchiver
29151 pnadmin   22   0  391m 334m 8992 S  1.0  4.1 261:26.75 process_inliner
25522 pnadmin   16   0  3104 1024  756 R  0.7  0.0   0:00.64 top
4069 root      34  19     0    0    0 S  0.3  0.0 315:11.31 kipmi0
    1 root      15   0  3588  564  476 S  0.0  0.0   6:04.45 init
    2 root      RT   0     0    0    0 S  0.0  0.0   0:55.36 migration/0
    3 root      34  19     0    0    0 S  0.0  0.0   0:02.87 ksoftirqd/0
Has anyone come across this problem and have a potential solution?
Mike
1 REPLY
Bronze
Re: Java Process Consuming 99% CPU
Hi Michael.
a recent bug CSCtf73095 just like this was actually fixed in 6.0.7 . since you are running that version already, i recommend you open a TAC case so it's investigated as this is likely a new bug.
Best Regards,
Fadi.
612
