Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problem with re-imaging local controller 210
I was downloading DVD image vers. 6.0.2. After installation process system not started. On the console i see "LI" communicate. Maybe the image is bad???
What is the solution?
Regards, Pawel
Re: Problem with re-imaging local controller 210
Compare the MD5 checksum of the image with the one mentioned on the site. If it does not match, re-download the image :).
Farrukh
The md5 checksum is correct. During the installation process appears communicates for example:" /cdrom/bin/tar: lib/modules.pcimap: Could not create file: No such file or directory". There are a few similar communicates. After finishing installation process and reboot device I see communicate: "Li".
Maybe the disk storage with RAID is bad?, but under the diagnostic program I can't see problem.
I tried with many versions of software: from 5.3.5 to 6.0.2 - there are similar problems.
Pawel
I would open a TAC Case at this point, if that is possible.
Farrukh
166
