Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Restore takes forever
I'm attempting a restore of a fresh install MARS 50 6.0.2. The restore process have been stuck at
"Invoking binary config importing procedure ...
Checking schema ...
Recreating the database schema.
Importing data into database ...
for the last 4 hours and the Oracle is running at 80%+ CPU. I'm only doing a config restore and the previous MARS 50 had only been running for some 4 months.
I've done a few restores of earlier versions and never had any problems. Anyone seen this before?
Fredrik
1 REPLY
Silver
Re: Restore takes forever
Backups may be confused when someone start archiving a new MARS-50 at 6.0.2 in the same directory as the old backups.
So separate out the invalid data from the valid.
139
