Static IP on ACS
I have a new ACS Solution engine 1113 running v4.1.1.23 and CSA build 4.0.1.543.2
I cant seem to configure a static IP address on the server. Each time I configure static IP entries via the console (IP address, DNS, Default gateway) and disable DHCP and reload the box it comes back up with either a DHCP address or a 169.x.x.x address.
Re: Static IP on ACS
This is a known issue, please find patch/workaround here:
http://www.cisco.com/en/US/ts/fn/New/fn63058.html
Please rate helpful posts.
Farrukh
Thank you. the patch did the trick.
138
