05-22-2008 10:34 AM
How do you learn the ip address of a device that MARS interprets as "Unknown reporting device"? Seems like it should be easy, but I cannot find it.
Solved! Go to Solution.
05-22-2008 12:15 PM
Create a report with 'Unknown Device Event Type' under Events and 'Unknown Event Report' as Query type -> Result format.
05-22-2008 12:15 PM
05-22-2008 12:36 PM
Thank you. That did it.
