Webcast- Automate Nexus9k
Community Member
CBWFQ on Switch Catalyst 3750
Does Switch cisco Catalyst 3750 support CBWFQ QoS?
I would like to understand if the IOS of the catalyst support the Bandwidth command to a class and offer a minimum bandwidth in congestion situation. I have some applications that need to increase its flow when the other classes is not using their bandwidth. On my 3750 I dont see the bandwidth command.
Thanks a lot.
1 ACCEPTED SOLUTION
VIP Purple
Hi you should not have to set
Hi you should not have to set mls qos, just use the service policy to apply it but from what i remember there's restrictions on 3750s i dont think you can apply the policy outbound only inbound but it may have changed in newer IOS, i have not tested it recently
 This is a good doc on 3750s qos
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_52_se/configuration/guide/3750scg/swqos.html#wp1766985
VIP Purple
Yes 3750s support CBWFQ , its
Yes 3750s support CBWFQ , its not about the hardware more the software thats running on it as its layer 3 software based qos unlike layer 2 which is hardware based qos
Community Member
Hi Mark,Thank you for
Hi Mark,
Thank you for response.
So I need to enable the (mls qos) to use the cbwfq or I can to make the follow config without mls qos:
policy-map xxxx
 class critical_data
  set ip dscp af41
    bandwidth percent 50
     random-detect dscp-based
     random-detect dscp 34 50 105
    queue-limit 148 packets
 class oam_map
  set ip dscp cs2
    bandwidth percent 5
 class voip_map
  priority percent 6
set ip dscp ef
 class svoip_map
  set ip dscp af31
    bandwidth percent 3
 class pacs_map
  set ip dscp af13
    bandwidth percent 20
 class class-default
    fair-queue
Community Member
Hi Mark,
In this case, when I use bandwidth command it´s possible a class use the bandwidth that is not in use for other class. In 3750x I only able to use police that limit my class and if it necessary more bandwidth and other class is not using all its band this class dont increase its band to be using police. Does it make sense Mark? Is it correct?
Thanks.
VIP Purple
Community Member
Hi thank you, this doc will
Hi thank you, this doc will help me!!
Super Bronze
Disclaimer
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
(A very belated response - but just stumbled across this thread - I believe some response information might not be 100% accurate.)
Yes 3750s support CBWFQ . . .
At least for egress, it is not like software based routers.  Feature wise, it's a subset, and its configuration can be quite different.
. . .  its not about the hardware more the software thats running on it as its layer 3 software based qos unlike layer 2 which is hardware based qos
3750 QoS is tied to its hardware, especially for egress.
Community Member
Thank you for your response.
Cheers.
3074
