02-17-2012 02:42 AM
hi
is the 3750ME capab;eof running isis on ipv6.I only see support for rip and eigrp.
thanks
02-17-2012 03:00 PM
no ISIS for IPv6 is not supported on Me3750.
Config guide documents it:
Unsupported IPv6 Unicast Routing Features
•IPv6 policy-based routing
•Full IPv6 virtual private network (VPN) routing and forwarding (VRF) table support
Note The switch supports IPv6 VRF-Lite (Multi-VRF-CE), which is IPv6 VPN in a VRF environment with limited VRF functionality.
•Support for Intermediate System-to-Intermediate System (IS-IS) routing
•IPv6 packets destined to site-local addresses
•Tunneling protocols, such as IPv4-to-IPv6 or IPv6-to-IPv4
•The switch as a tunnel endpoint supporting IPv4-to-IPv6 or IPv6-to-IPv4 tunneling protocols
•IPv6 unicast reverse-path forwarding
•IPv6 general prefixes
•IPv6 HSRP
Riccardo
02-19-2012 11:10 PM
hi Riccardo,
thanks for your prompt response.So what would be a work around in an
MPLS network that is running isis with 3750s as PE devices.How would we
route ipv6 in this case,cnt changing the ios fix the issue.
02-20-2012 12:49 AM
unfortunately changing IOS won't help.
Which type of ipv6 prefixes you need to advertise?
Riccardo
02-20-2012 12:58 AM
hi Riccardo;
im trying to advertise a ULA prefix just within the metro core.The ULA
prefix is used on looback and p2p.
