7600 Master SUP720 NSF SSO
master sup failed and i got new sup; wat are the steps I need to follow to install newly recvd SUP720.
1 REPLY
Re: 7600 Master SUP720 NSF SSO
Do make sure that you have identical ios available in the new sup.
AFAIK you can install the same and make sure that its booted up and ready to take over from the current active sup.
you can check out the status of the sup/redundancy usin show module/show redundancy commands.
if you desire to make this new sup to become active then you need to issue forced failover command to make this new sup as active sup.
regds
220
