7600-SIP-200 configuration doubt very urgent
dear all,
i'm new to 7600-sip-200 and oc3 related configurations.
i've 2 6506-E switches one is in my office and one is 10km's away supervisor engine is Ws-SUP32-GE-3B which is installed on 5th slot of the switch IOS is 12.2 and i've 7600-SIP-200 SPA interface processor installed on 1st slot and SPA-2XOC3-POS installed in it with SFP-OC3-IR1 my requirement is i need a point to point connection between these two switches.
ihave no idea regarding this i'm new to these hardwares, basically connections will be like p-t-p connection between 2 SFP-OC3-IR1. ATM configuration is required for this? Can anybody suggest or give any sample configuration or guidance to configure these items.
joseph
1 REPLY
Re: 7600-SIP-200 configuration doubt very urgent
ATM encap wont be reqd and supported for this.
Only HDLC, PPP, or Frame Relay.
Here is a detailed config guide for this SPA.
http://www.cisco.com/en/US/products/hw/routers/ps167/products_configuration_guide_chapter09186a0080588607.html
HTH-Cheers,
Swaroop
167
