ATM OC-3 Multimode in a 7206 using 50/125mm Fibre.
Can this type of interface use 50/125mm Fibre to connect devices over short distances?
CCO says that it needs 62.5/125 but its also says it supports distances of up to 2k.
We wouldn't need any more the 200-300 metres.
1 REPLY
Green
Re: ATM OC-3 Multimode in a 7206 using 50/125mm Fibre.
It should work fine. As you suspect, you'll lose some signal due to the core size mismatch, but you should still have enough to make the short haul (and you'll probably still need attenuation).
Good Luck
Scott
148
