can i use pos 622M as a pos 155M interface, module is SPA-1XOC12-POS
SPA-1XOC12-POS can use as a 155M sdh POS interface?
this is on 7609 sip 400,not a channelized oc 12 interface.
if i connect a 155 M sdh line into this 622M interface,it is single mode fiber. does this work?
thank you!
1 ACCEPTED SOLUTION
Re: can i use pos 622M as a pos 155M interface, module is SPA-1X
Hi flyjunli,
I'm quite sure this won't work. The framing won't fit if you connect different interfaces.
BR
Sebastian
hmmmm....I don't think this is supported. Anyone else know this?
Hi flyjunli,
BR
Sebastian
241
