CISCO 3271
what is the fast swtiching cef kpps of a 3271? For example a 2801 is 110.000 approx. Why are there no performance stats published anywhere ? And what of the 3230?
Re: CISCO 3271
You may want to check the performance stats with your Cisco local account SE.
He would give you first hand and accurate info about the same.
HTH-Cheers,
Swaroop
Re: CISCO 3271
Will I be pleased or depressed do you think ?
I did forward a mail to my rep.
196
