Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Cisco 7200 as BRAS
does anyone of you know if you can use a Cisco 7200 as a BRAS? We were told it is possible, but I am not able to find an IOS image with PPPoE support.
Any pointers are welcome.
TIA
NaNa
Re: Cisco 7200 as BRAS
I have used 3 years ago, it does the job....I cannot recall the exact IOS version. I guess if I did I would be labeled a nerd.
try features/IOS selector to find what u need.
Things to watch out for with 7200...it does not cope very well with VoIP small packets.
sorry I don't have much more to say
Sam
uh, sorry.
I mistyped, I am looking for BRAS support in the Cisco 7600, not 7200.
My bad. The 7200 is commonly used as a BRAS, so IOS support is easy to find.
But the 7600 is another story entirely.
So, can the 7600 be a BRAS?
TIA
NaNa
As far sa I know, you can get ISG
(http://www.cisco.com/en/US/products/ps6566/products_configuration_guide_book09186a008061ab53.html)
features on 7600 platform but only for IP sessions, not for PPP.
These functions should be available on on SIP-400.
Thanks for the tip, but ISG does not support 7600.
As for the SIP-400, it does not support PPPoE.
It seems the only option is to use the MWAM card.
thanks for your tip.
NaNa
1023
