Community Member
EoMPLS problem with 6500 and IOS SXF6 + SXE5
My EoMPLS stopped working after one ge-wan interface gone down and up.
Before the down it was working fine.
The connection is between two 6500 switches, trough GE-WAN (OSM+4GEWAN) ports.
One swith have IOS 12.2(18)SXF6 and the other is using 12.2(18)SXE5
Any incompatibilities between the IOS ?
or maybe another problem or BUG ?
Community Member
Re: EoMPLS problem with 6500 and IOS SXF6 + SXE5
What did you do to fix this issue?
Community Member
I did a RMA for the OSM module.
Community Member
Did this help ? What I meen is: have you had another up/down after you have changed the OSM and did the EoMPLS worked fine after this up/down ?
285
