03-27-2006 11:54 AM
Hi!
I have a 2950 switch with two gigabit and 24 Fastethernet ports. I am trying to reach a capacity of 200 Mbps by using etherchannel between the switch and the router. Two FE ports both at the switch and router sides are included in the etherchannel. Does port-channel load balance the traffic between the switch and the router? Or at least does port-channel start using the second FE port when the first one is saturated? Uplink to the upper carrier is connected through one of the gigaethernet ports, which means all the traffic comes from only one MAC address and goes to an other MAC address at the router side.
Thanks so much for the answers.
Nedim KARACA
03-27-2006 01:19 PM
There is a comprehensive information at:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat5000/rel_5_2/config/channel.htm#xtocid252423
I hope it would help you.
Vladislav Vasilev
03-28-2006 01:33 PM
Hi Vladislav!
Thanks for your answer, but it did not help solving my problem.
I appreciate any other help.
Nedim KARACA
03-31-2006 12:12 PM
Yes, Etherchannel can perform load balancing.
I have a document explaining etherchannel load balancing. I believe this will be helpful to you.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
05-12-2006 07:01 PM
Mr. Hsu,
This is very good information. Can you point me to the docs for configuring the router side of the etherchannel?
--- never mind, I found it... ---
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094958.shtml
John
05-26-2006 12:10 AM
Dear Friend
I have same problem with 3500XL switches .
Load balancing algorithm on 2950 is based on src and dst MAC.
I thnik you should use another switch like 3550
Etherechannle load balancing using 2950 switch is not good on your case
look at this
