Ethernet Pseudowire over IP/MPLS
Hello there,
Anyone has any case study example regarding transmitting Ethernet PW over MPLS/IP core network?
Do you have an example you would like for me to share a configuration for.
IE.
(ME3800switch)==(7609router)==MPLS Core==(7609router)==(ME3750switch)
Need to carry point to point 1gig circuit from CustomerA Site1 to CustomerA Site 2
or perhaps a point to multipoint Bank/Branch situation.
I have almost every configuration possible existing in my core network today.
Jude Bryant
Network Engineer
Pioneer Telephone
Re: Ethernet Pseudowire over IP/MPLS
Yep.
Are you aggregating on SVI's or the physical interfaces on your PE routers? Port-based or Vlan-based?
Hi chris,
Here is a link gives you brilliant explanation and also exampls configuration for EoMPLS and other stuff.
In fact this is taken from the  Layer 2 VPN Architectures book by Cisco Press. I found it extremely helpful. It covers both the modes RAW mode(port based) and TAGGED mode(vlan based mode)
http://fengnet.com/book/Layer%202%20VPN%20Architectures/ch07.html#idd1e13647
Kishore
2511
