GRE over MPLS
Has anyone here implemented "GRE over MPLS"?
Would it be possible to point to some links discussing advantages/disadvantages and some design aspects of the same?
Cheers,
~sultan
Silver
Re: GRE over MPLS
Where do you mean to enable the GRE ? At CE or at PE side ?
If enable at CE, it is just like normal GRE setting and no special command.
If enable at PE, it is not recommended due to high CPU loading to all VRFs.
Hope this helps.
Re: GRE over MPLS
Hi Sultan,
Not quite sure, what is the expected implementation. Can u take some time to elaborate the same.
Swaroop
Re: GRE over MPLS
Hi Swaroop,
Actually I was just being paranoid about this...
I went ahead and tested the same successfully, wanted to know the whether the tunnel status incase of MPLS core links going down and such stuff... got the appropiate traps...
Basically just wanted to know from the guys in here about any issue that might have been encountered.
But since now having tested the same there is no problem.
Thanks for your kind reply...
Cheers,
~sultan
Re: GRE over MPLS
Hi Sultan,
Since you have tested it, thats the best way to go.
Cheers,
Swaroop
Re: GRE over MPLS
Hi Swaroop
Can you pm your number to my mail id ?
regds
Silver
Re: GRE over MPLS
maybe that's not so usefull for your requirements, but I've used gre tunnel on MPLS topology just to transport multiple vpn on the same site (vrf lite).
Normally I prefer different VLAN or PVC, but in some cases I've used GRE tunnel over FR on the same PVC.
However see that:
http://www.cisco.com/en/US/tech/tk436/tk428/technologies_configuration_example09186a00801e1294.shtml
Andrea
Re: GRE over MPLS
Hello All,
Thanks for all the answers, I did manage to test the same and found out that I was being paranoid without giving much thought to it...
Cheers
~sultan
297
