H-VPLS with MPLS in access
Hi NetPros
We use some 3rd party and xDSL based aggregation networks for Ethernet services.
They often have some L2CP and other transparency limitations or at least quite different behaviour.
Due to that fact I'm thinking of using MPLS in the access as most 3rd party aggregation networks are transparent for MPLS ethertpyes.
In our lab I already did some first tests with P2P which worked fine (beside throughput with small packets).
Now I tried to create MP2MP services. H-VPLS with MPLS access is'nt working so far.
As N-PE we use 7600+RSP720+ES20, IOS version 15.2(1)S1 (core and access links on ES20)
As U-PE (or PE-CLE) we tried with ISR G2 (2921), ASR1001, 892F and 888E.
Does someone maybe have a working configuration with similar setup?
Maybe someone could share a more detailed sample configuration for ME-H-VPLS?
Routing is fine; LDP is up; but N-PE complains about no local binding
N-PE lab config:
mpls label protocol ldp
mpls ldp discovery targeted-hello accept
mpls ldp router-id Loopback0 force
l2 vfi rd-party-test manual
vpn id 10
! remote N-PE:
neighbor 192.168.0.3 encapsulation mpls
! U-PE:
neighbor 192.168.0.45 100 encapsulation mpls no-split-horizon
interface Loopback0
ip address 192.168.0.4 255.255.255.255
interface GigabitEthernet1/0/4
description interface facing to U-PE
service instance 100 ethernet
  encapsulation dot1q 100
  rewrite ingress tag pop 1 symmetric
  bridge-domain 100
interface Vlan100
mpls ip
U-PE lab config:
interface Loopback0
ip address 192.168.0.45 255.255.255.255
interface GigabitEthernet0/1
description interface facing to customer
xconnect 192.168.0.4 100 encapsulation mpls
  mtu 1500
interface GigabitEthernet0/0.100
description interface facing to N-PE
encapsualtion dot1q 100
ip address 192.168.1.45 255.255.255.0
mpls ip
On N-PE:
Apr 15 23:32:12.096 cet-sum: AToM LDP[192.168.0.45]: Session is up
Apr 15 23:32:12.096 cet-sum: %LDP-5-NBRCHG: LDP Neighbor 192.168.0.45:0 (8) is UP
Apr 15 23:32:12.100 cet-sum: AToM LDP[192.168.0.45, 100]: LDP open
Apr 15 23:32:12.100 cet-sum: AToM LDP[192.168.0.45, 100]: Signaling peer-id of VC changed to 192.168.0.45
Apr 15 23:32:12.100 cet-sum: AToM LDP[192.168.0.45, 100]: LDP UP
Apr 15 23:32:12.100 cet-sum: AToM[192.168.0.45, 100]: Evt ldp up, provisioned -> ldp ready
Apr 15 23:32:12.100 cet-sum: AToM[192.168.0.45, 100]: . Take no action
Apr 15 23:32:12.104 cet-sum: AToM LDP[192.168.0.45]: Peer address change, add 192.168.0.45
Apr 15 23:32:12.104 cet-sum: AToM LDP[192.168.0.45]: Peer address change, add 10.0.37.1
Apr 15 23:32:12.108 cet-sum: AToM LDP[192.168.0.45]: Received label mapping msg, id 10500 GR 8 vc type 4, cbit 1,
Apr 15 23:32:12.108 cet-sum: AToM LDP[192.168.0.45]:   vc id 100,
Apr 15 23:32:12.108 cet-sum: AToM LDP[192.168.0.45]:   group id 0, vc label 16,
Apr 15 23:32:12.108 cet-sum: AToM LDP[192.168.0.45]:   status 0x7/LDP 0x1/ADJ 0x0,
Apr 15 23:32:12.108 cet-sum: AToM LDP[192.168.0.45]:   mtu 1500, peer vlan id 0   , vc handle 0x3600000A
Apr 15 23:32:12.108 cet-sum: AToM LDP[192.168.0.45]:   VCCV cc flags 0x3 cv flags 0x2
Apr 15 23:32:12.108 cet-sum: AToM LDP[192.168.0.45, 100]: Receive label adv
Apr 15 23:32:12.108 cet-sum: AToM LDP[192.168.0.45, 100]: Signaling peer-id of VC changed to 192.168.0.45
Apr 15 23:32:12.108 cet-sum: AToM[192.168.0.45, 100]: Evt remote ready, ldp ready -> remote ready
Apr 15 23:32:12.108 cet-sum: AToM[192.168.0.45, 100]: . Receive remote vc label binding, instance 8
Apr 15 23:32:12.108 cet-sum: AToM[192.168.0.45, 100]: . Adjacency : No fault
Apr 15 23:32:12.108 cet-sum: AToM[192.168.0.45, 100]: .. S:Evt ADJ up in LndRnd
Apr 15 23:32:12.108 cet-sum: AToM[192.168.0.45, 100]: .. S:Evt dataplane clear fault in LndRnd
Apr 15 23:32:12.108 cet-sum: AToM[192.168.0.45, 100]: . Check if remote connected
Apr 15 23:32:12.108 cet-sum: AToM[192.168.0.45, 100]: .. Remote label is ready
Apr 15 23:32:12.108 cet-sum: AToM[192.168.0.45, 100]: .... S:Evt remote ready, LndRnd -> LndRrd
Apr 15 23:32:12.108 cet-sum: AToM[192.168.0.45, 100]: .... S:Evt remote up, LndRrd -> LndRru
Apr 15 23:32:12.108 cet-sum: AToM[192.168.0.45, 100]: .... S:Act send SSS(UP)
Apr 15 23:32:12.108 cet-sum: AToM[192.168.0.45, 100]: .....  [no service]
Apr 15 23:32:12.108 cet-sum: AToM[192.168.0.45, 100]: .... S:Evt ADJ up in LndRru
Apr 15 23:32:12.108 cet-sum: AToM[192.168.0.45, 100]: .. Yes, connected
show mpls l2transport vc vcid 100 detail
Local interface:   down
  Interworking type is Ethernet
  Destination address: 192.168.0.45, VC ID: 100, VC status: down
    Output interface: none, imposed label stack {}
    Preferred path: not configured
    Default path: no route
    No adjacency
  Create time: 00:42:48, last status change time: 00:02:29
  Signaling protocol: LDP, peer 192.168.0.45:0 up
    Targeted Hello: 212.161.178.225(LDP Id) -> 192.168.0.45, LDP is UP
    Status TLV support (local/remote)   : enabled/supported
      LDP route watch                   : enabled
      Label/status state machine        : remote ready, LndRru
      Last local dataplane   status rcvd: No fault
      Last BFD dataplane     status rcvd: Not sent
      Last local SSS circuit status rcvd: DOWN(not-forwarding)
      Last local SSS circuit status sent: Not sent
      Last local  LDP TLV    status sent: None
      Last remote LDP TLV    status rcvd: No fault
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local unassigned, remote 16
    PWID: 40988
    Group ID: local unknown, remote 0
    MTU: local unknown, remote 1500
    Remote interface description:
  Sequencing: receive disabled, send disabled
  Control Word: Off (configured: autosense)
  VC statistics:
    transit packet totals: receive 0, send 0
    transit byte totals:   receive 0, send 0
    transit packet drops:  receive 0, seq error 0, send 0
Everyone's tags (2)
umm , the below bit worries me. why have u got MTU 1500 under ur xconnect command on your U-PE. can u take it off and see what happens?
MTU: local unknown, remote 1500.
Also there could be smoething to do with the VC type. The N-PE is receiving a  vc type 4 from the U-PE. but its local vc type is 5(port based ethernet).
can you please paste the below on the U-PE and see if that helps.
pseudowire-class ip-interworking
encapsulation mpls
interworking ip
xconnect 192.168.0.4 100 pw-class ip-interworking
Kishore
Hi Kishore
You brought me closer to a working configuration I guess.
First I changed configurations everywhere "vc-type 5" is used.
I also checked MTU is everywhere the same.
I also had to add a local SVI to the VFI on N-PEs.
After that N-PE full mesh VPLS is up and running.
But all spoke pseudowires and SVI interface on N-PE now flap constantly exactly every 15 seconds:
On N-PE:
Apr 17 09:28:37.531: %LINK-3-UPDOWN: Interface Vlan335, changed state to up
Apr 17 09:28:37.535: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan335, changed state to up
Apr 17 09:28:37.631: %LINK-3-UPDOWN: Interface Vlan335, changed state to down
Apr 17 09:28:37.635: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan335, changed state to down
Apr 17 09:28:52.624: %LINK-3-UPDOWN: Interface Vlan335, changed state to up
Apr 17 09:28:52.628: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan335, changed state to up
Apr 17 09:28:52.720: %LINK-3-UPDOWN: Interface Vlan335, changed state to down
Apr 17 09:28:52.724: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan335, changed state to down
Apr 17 09:29:07.808: %LINK-3-UPDOWN: Interface Vlan335, changed state to up
Apr 17 09:29:07.812: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan335, changed state to up
Apr 17 09:29:07.912: %LINK-3-UPDOWN: Interface Vlan335, changed state to down
On U-PE:
%XCONNECT-5-PW_STATUS: MPLS peer 192.168.0.4 vcid 100, VC UP, VC state UP
%XCONNECT-5-PW_STATUS: MPLS peer 192.168.0.4 vcid 100, VC DOWN, VC state DOWN
Any idea what could cause flapping?
1999
