11-12-2009 05:40 AM
Hi everyone,
I'm wondering if anyone in the community has encountered this strange behaviour on a 3400EG-12CS.
Last night after upgrading the IOS on a few of these switch models, I noticed that ports with an SFP installed were coming up as 1000/half. At first I thought it may have been the IOS I was moving too (12.2.52se), but I reverted to several IOS versions to only get the same results.
Below is an example of the "show int status" of one of the switches:
vds4#show int status
Port Name Status Vlan Duplex Speed Type
Gi0/1 sem01_Port3 connected 464 half 1000 1000BaseSX SFP
Gi0/2 sem02_Port3 connected 464 half 1000 1000BaseSX SFP
Gi0/3 sem03_Port3 connected 464 full 1000 1000BaseSX SFP
Gi0/4 sem04_Port3 connected 464 full 1000 1000BaseSX SFP
Gi0/5 sem05_Port3 connected 464 half 1000 1000BaseSX SFP
Gi0/6 sem06_Port3 connected 464 half 1000 1000BaseSX SFP
Gi0/7 sep01r_Port1 connected 464 full 1000 1000BaseSX SFP
Gi0/8 FST-HEMI-01 Media connected 464 a-full a-1000 10/100/1000BaseTX
Gi0/9 mmc01_Port8 notconnect 464 auto auto Not Present
Gi0/10 notconnect 464 auto auto Not Present
Gi0/11 notconnect 464 auto auto Not Present
Gi0/12 MPEG Analyzer disabled 464 auto auto 10/100/1000BaseTX
Gi0/13 vds2_Gi0/1 connected trunk full 1000 1000BaseSX SFP
Gi0/14 vds2_Gi0/2 connected trunk full 1000 1000BaseSX SFP
Gi0/15 disabled 1 auto auto Not Present
Gi0/16 disabled 1 auto auto Not Present
Po1 connected trunk full 1000
Fa0 OOB Management (VM connected routed a-full a-100 10/100BaseTX
vds4#
vds4#show run int g0/1
Building configuration...
Current configuration : 110 bytes
interface GigabitEthernet0/1
description sem01_Port3
switchport access vlan 464
media-type sfp
end
vds4#
Some of the switches have an Port-Channel and they would come up in suspend. I'm suspecting due a duplex mismatch.
I also don't see any errors on the ports that are coming up as 1000/half which is weird.
The only way I am currently able to resolve this issue, is to move the sfps to a new port. Clearing the config/rebuild and re-seating the SFP doesn't seems to work.
Any thoughts would be greatly appreciated.
Thanks in advance
-- Dominique
03-25-2011 06:02 PM
I do not have a soultion, but can say I just saw the same thing... We kept trying to change it but no luck. This happened for us after an OS upgrade as well. We also did not see any errors.. I know this is an old post, but gee it was interesting/annoying.
03-29-2011 06:28 AM
Hi Dominique and Stuart,
the issue looks like CSCtf71229 "ME-3400E: SFP negotiating at half duplex "
Symptom:
When ME-3400E reload or Optical cable re-insert, SFP negotiating at half duplex(suspended)
Conditions:
Gi0/1 Gi0/51
[ME-3400EG-2CS-A]==========(Po1)===========[WS-C2350-48TD-S]
Gi0/2 Gi0/52
* These switches connected with Optical cable + SFP
* This issue occurs:
-IOS version : 12.2(53)SE, 12.2(50)SE3
-ME-3400 E series only.
-speed nonegotiate(1000/Full Hardcoded)
* This issue NOT occur:
-speed and duplex is 1000/auto
-ME-3400(*NOT* E series)
Conditions:
Workaround:
-speed and duplex is 1000/auto.
It is solved in 12.2(55)SE / 12.2(52)EY and will be solved in 12.2(58)SE too
Riccardo
09-25-2011 05:09 PM
I am having the same problem with several ME-3400EG-12CS-M's running IOS 12.2(54)SE as well. The suggested fix to CSCtf71229 listed on http://www.cisco.com/en/US/docs/switches/metro/me3400e/software/release/12.2_54_se/release/notes/OL22235.html is to set duplex auto and speed auto however you cannot do this while the media type is set to sfp. If you change the media type to auto or remove the sfp type the link still comes up at half duplex, so it looks like I will be upgrading to 12.2:55)SE to attempt to resolve this.
08-27-2012 02:01 PM
Looks like ME3400 is foster child for Cisco - so many bags.
This bag CSCtf71229 you mentioned is not 100% correct:
If you setup media to SFP you CAN NOT define speed & duplex on interface - your only option is "speed nonegotiate" or to remove it.
At the same time it looks like cosmetic issue - our ISP has 1000/full and we don't have any errors/collisions (its why we will probably keep rinning current 12.2.54SE till other major issue comes up):
GigabitEthernet0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is b4a4.e3ce.9681 (bia b4a4.e3ce.9681)
Description: ""
MTU 9000 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 7/255, rxload 23/255
Keepalive set (10 sec)
Half-duplex, 1000Mb/s, link type is force-up, media type is 1000BaseLX SFP
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 93627000 bits/sec, 11102 packets/sec
5 minute output rate 29837000 bits/sec, 7361 packets/sec
17372242746 packets input, 16939562380170 bytes, 0 no buffer
Received 119066 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
12673148915 packets output, 6709051282693 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
Transmit GigabitEthernet0/1 Receive
317362230 Bytes 231526071 Bytes
4083206873 Unicast frames 192273207 Unicast frames
16718 Multicast frames 0 Multicast frames
481 Broadcast frames 119066 Broadcast frames
0 Too old frames 223905847 Unicast bytes
0 Deferred frames 0 Multicast bytes
0 MTU exceeded frames 7620224 Broadcast bytes
0 1 collision frames 0 Alignment errors
0 2 collision frames 0 FCS errors
0 3 collision frames 0 Oversize frames
0 4 collision frames 0 Undersize frames
0 5 collision frames 0 Collision fragments
0 6 collision frames
0 7 collision frames 2600442110 Minimum size frames
0 8 collision frames 1541479797 65 to 127 byte frames
0 9 collision frames 886205270 128 to 255 byte frames
0 10 collision frames 679557526 256 to 511 byte frames
0 11 collision frames 577137202 512 to 1023 byte frames
0 12 collision frames 2497504960 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 0 Symbol error frames
0 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 0 Valid frames, too large
0 Excess defer frames 0 Invalid frames, too small
2758289607 64 byte frames 0 Valid frames, too small
135451202 127 byte frames
536748413 255 byte frames 0 Too old frames
386693070 511 byte frames 0 Valid oversize frames
685003659 1023 byte frames 0 System FCS error frames
3876005417 1518 byte frames 0 RxPortFifoFull drop frame
0 Too large frames
0 Good (1 coll) frames
0 Good (>1 coll) frames
07-03-2016 08:23 PM
I upgraded to Version 12.2(55)SE9, it's not solve. I will try to change OFC or transceiver.
