Community Member
help high CPU rate on GSR ??
Hello
I have a question,One GSR running IOS 12.0(17)S and CPU rate is below 10%.Now I upgraded this GSR to 12.0(26)S which is newnest version on CCO.Now I found that the CPU rate on grp is above 90%.the most part of CPU is used by process ip input.Between this upgrade ,I did not any configuation change.Can anyone enconter this problem ?thank you in advance ??
1 REPLY
Bronze
Re: help high CPU rate on GSR ??
I have heard about similar problems in this version with certain linecards and protocols. Check for known issues if you have access to Bug toolkit.
200
