How to communicate between UNI ports?
I have a new  ME3400 series switch with IOS (me340x-metrobase-mz.122-37.SE1), it has 24 fastethernet and 2 gig fiber uplinks
Now all the ports except fiber uplinks are uni ports by default.
So can't communicate with each other. Now i wishes to make them communicate while remaining in uni port-type.
On forums the solution is to declare them as member of community vlan.
My questions are
1) can i no shut the secondry vlan interface?
2) From which pool i have to give ip to my system either from primary vlan pool or secondry vlan pool?
3) In both cases i can't communicate with the default gateway i.e: the ip of vlan even the port is member of community vlan. so how to communicate them while being in uni ports?
The sh run of switch is below
Switch#sh run
Building configuration...
Current configuration : 2088 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
system mtu routing 1500
ip subnet-zero
no file verify auto
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan 100
  private-vlan primary
  private-vlan association 101-102
vlan 101
  private-vlan isolated
vlan 102
  private-vlan community
interface FastEthernet0/1
switchport private-vlan host-association 100 101
switchport mode private-vlan host
interface FastEthernet0/2
switchport access vlan 102
switchport private-vlan host-association 100 102
interface FastEthernet0/3
interface FastEthernet0/4
shutdown
interface FastEthernet0/5
interface FastEthernet0/6
shutdown
interface FastEthernet0/7
shutdown
interface FastEthernet0/8
shutdown
interface FastEthernet0/9
shutdown
interface FastEthernet0/10
shutdown
interface FastEthernet0/11
shutdown
interface FastEthernet0/12
shutdown
interface FastEthernet0/13
shutdown
interface FastEthernet0/14
shutdown
interface FastEthernet0/15
shutdown
interface FastEthernet0/16
shutdown
interface FastEthernet0/17
shutdown
interface FastEthernet0/18
shutdown
interface FastEthernet0/19
shutdown
interface FastEthernet0/20
shutdown
interface FastEthernet0/21
shutdown
interface FastEthernet0/22
shutdown
interface FastEthernet0/23
shutdown
interface FastEthernet0/24
shutdown
interface GigabitEthernet0/1
port-type nni
interface GigabitEthernet0/2
port-type nni
interface Vlan1
ip address 192.168.0.1 255.255.255.0
no ip route-cache
interface Vlan100
ip address 10.10.100.1 255.255.255.0
no ip route-cache
interface Vlan101
no ip address
no ip route-cache
shutdown
interface Vlan102
no ip address
no ip route-cache
shutdown
no ip http server
control-plane
line con 0
line vty 5 15
end
Any help will be apritiated and thanks in advance
825
