Community Member
ME-3400G-2CS as default gateway for a LAN
Hello.
We want to use a ME-3400G-2CS with IOS METRO IP as router CE for access to an MPLS VPN.
The ME-3400 will be the default gateway about 1500 IP Client.
Are there problems for this configuration (arp-table dimensions and so on)?
Thanks.
1 REPLY
Silver
Re: ME-3400G-2CS as default gateway for a LAN
As far as I know ME-3400G-2CS can be used for Layer 2 and layer 3 VPN services. Check the Datasheet available at http://cisco.com/en/US/prod/collateral/switches/ps6568/ps6580/product_data_sheet0900aecd8034fef3.html to verify if it supports your configuration.
194
