Community Member
ME 3750 and shaping
I'm a newbee to the 3750 ME switch , we received a demo 3750 switch from Cisco to do some testing with shaping.
We would have several customers connected to the 3750 switch and each of them will be placed in a separate vlan. In this way we can shape each customer to his bandwidth.
This is my config:
class-map match-all icmp
match vlan 2
policy-map test
class class-default
policy-map icmp
class icmp
shape average 32000
int fa1/0/1
switchport mode trunk
speed 100
duplex full
When I try to activate the policy map I get the following error message
cisco_demo(config-if)#service-policy output icmp
00:26:01: cqm_check_service_policy: Assigning a policy to output side of an unsupported interface
Does anybody have an idea ?
PS: What does ES interface mean ?
thx
wim
Re: ME 3750 and shaping
Try attaching this policy map to you ES interfaces for it to work.
MPLS and some QOS features can be configured only on the ES ports
(Enhanced Services)port for it to work.
The ES ports would be your Gi1/1/1 Gi1/1/2.
HTH-Cheers,
Swaroop
Community Member
in the 3750ME platform (as in the 3750) you have to use srr-queue for output policing.
HTH,
Alex
Community Member
ES stands for Enhanced Services.
Only some of the interfaces on the 3750 are ES. If you try to apply an advanced service like your service-policy to a non ES interface you get the error message.
I wish all interfaces were ES, but no joy.
Eric
Silver
I have also encountered problems when matching on VLAN interface. Try matching on ACL and see if that works.
387
